The Mackie BigKnob Passive has two sets of balanced source and two sets of balanced monitor (TRS) jacks, plus headphone.
Passive
Volume (down to -100dB)
Stereo / Mono
Mute
Dimm
No clicks whatsoever (!) switching source and/or monitor
So, if someone pushes the source select, and you listen and have your eyes closed, you hear nothing except the difference between the two sources. And if you group those in Roon and then match their volumes, you have a fully blind A/B test.
Seen in the picture are an RPI 3 B+ with a HifiBerry DAC+ Pro XLR (balanced) and an ifi iDAC 2 (unbalanced), which I am comparing trying to decide which I like best.
What does the switcher do to the sound, perhaps you ask?
Not much:
Frequency Response 0 dBu Input: ±1 dB, 10 Hz – 30 kHz Distortion (THD+N) 0 dBu Input @1 kHz: <0.005 % Crosstalk (20 Hz – 20 kHz) 0 dBu Input @1 kHz: <–85 dB Attenuation Muted: –100 dB Signal-To-Noise Ratio A–weighted: <–100 dB
For A/B purposes, I guess you could say it doesn’t even have to have such great specs, as long as the sources are both affected the same you can make a comparison. Of course it helps that the switcher is as transparent as possible, so you can hear the most of your sources.
When I am not comparing DACs, I connect my amps directly to whatever unit I’m using, so the BigKnob is not in the chain all the time.
However, as stated, I find it not audible (however, and there is the joke; I’d have to A/B with and without the switcher to state that objectively, right?)
here then a post detailing a ROCK running in a Linux KVM VM on a CentOS 7.6 Server.
The VM has 2GB and 2 vCPUs, a SATA disk (using a 20GB qcow3 disk image), because sadly VirtIO disk drivers are not included in the ROCK image, but nicely enough a VirtIO network card worked fine.
ROCK says Roon Database has 91% of 16 GB available with about 11,000 Songs indexed.
Performance is fine, and seems to be the same as on a Roon core running in a Windows 10 VM, and same as a Roon core running natively on the CentOS Server.
Two disadvantages of ROCK seem to be a) doesn’t run extensions b) is fixed to a UTC time zone, causing Squeezeboxen to show UTC time.
First Post, still in my trial period but will be signing up for a year. Had the core running on my 2015 MBP serving several zones in 3 buildings on my local network. Wanting to separate the core and processing from my work computer I decided to try the ROCK install on some pretty old hardware.
It’s an ancient 2007 Aopen DE965-HG with 4GB RAM and a T7250 C2D processor and a 120GB SSD. Loaded up the disk image onto a usb key with Etcher and bam! Perfect install first round, it updated it’s OS, loaded the ffmpeg codex no problem, transferred my core backup to the Aopen and it’s in the process of assimilating all the music as I type. I’ve already tried different zones like my AppleTV (3rd gen), Airport Express (old G variant), iPhone and MBP running 3 of them at a time and this is while the ROCK is still trying to index everything. Yes, the fan is running full tilt right now - we’ll see how it goes after the indexing is complete and I can probably mod it and replace the fan with a giant heatsink. Right now it’s streaming to the Roon app on my MBP and being output into a virtual soundcard - Sonarworks 4 Systemwide.
I plan to use Roon convolution to replace my MiniDSP 4x10 for active XO and room correction on my 3.3 (3 way speakers + 3 subs for even distribution) but haven’t gotten as far as firing up REW and rePhase yet to make filters. I’ll update here once I get that figured out and report how this old tech works for that task. I figure despite it’s age it’s already more powerful than a MiniDSP SHARK platform.
These things go for as little as $30.00 on eBay BTW…
I think if this is used purely to serve Roon you may be OK but if you try any demanding DSP it will probably run out of steam. Definitely worth doing though.
Well it all worked just fine for the past 5 days to serve Roon to everything but I’ve decided to run it as a Linux host on a new HD so I could utilize some extensions but I have the ROCK HD set aside and can swap it out to experiment with later. As of now my core is back on the MBP until I sort out the Roon Linux install. I’ve yet to try my hand at any convolution filters but when I do I’ll report back how the ROCK install does with them on this machine.
Eighteen day update. I tried an Ubuntu set up but settled on Win7 32 as a server so this machine could also do double duty as a Plex server for video. It’s actually got a decent optical drive so I’m using it as a ripping machine as well with Exact Audio Copy app directly to the networked media drive as well as a local USB one. I run it headless and just screen share from my Macbook Pro when I need access or ripping CDs.
I still haven’t used it for XO convolution but have set up some filters via REW and Rephase using 262k taps, bit depth conv, volume leveling, headroom mgt, sample rate conv, and para EQ all going and I can see where a more powerful processor may be in order for trying the XO bit as the processing speed is around 10x. I’ve picked up a cheap USB 8 channel sound card so I’ll give it a try anyway and report back one more time but will probably move things over to a 2012 Mac Mini for the final job.
For basic server functions and even the extreme bit of DSP I’m using right now one of these ancient little boxes works just fine. Not a single stutter in 18 days.
Not as a server an endpoint only. I’m looking for a low cost alternative to replace raspberrypi as usb on pi is just rubbish and I get ticks and clicks. It also needs wireless. I’ve already tried Allo Bridge a year ago and did not like it due to stability.
The board I used was the DE3815 single core Celeron NUC. Gigabit Ethernet, USB 2 and 3, ddr3 memory slot, a pci-e slot for wireless and the ability to use a SATA DOM if you don’t want to run ROCK on a full sized SSD. It has a passive heat sink and is not demanding power wise. They are end of life now but you could buy them as a board only two or three years ago. This will not be the cheapest solution but it does work very well.
So is my hifiberrys I have three of them, but this one does not use a HAT as the DAC/Headphone Amp is USB only. Pi is piss poor with usb on any os. Hence my look get something better but at a low outlay.
Found one for £72 on eBay. It’s been bought, have some spare memory lying around which is the right sort to so saved me a few pennies. I’ll look at getting the wireless card after tested it for a bit as I have a wireless bridge I can use temporarily.
Never used it, I never purchased a WiFi module for it, but that does mean you can choose your module to guarantee a good match.
Edited to say the above is in response to your question about WiFi.
Mine was run using 12 volt batteries. It’s primary benefit was that when I used SBC’s I was always able to find their limits be that OS or hardware. The NUC was properly designed. When it said gigabit Ethernet it meant it. And USB doesn’t share real estate with any other function. If you simply load ROCK and it assigns itself an IP your core will pick it up. No need to sign in, no need to acknowledge its existence after you are given the choice of which core you wish to use. But updates will need to be manual through the admin web page.
