I’m about to buy a Chord Mojo 2 for my iPhone 12 which of course just has a lightning port.
I’ve read that I need to purchase an Apple Lightning to USB (camera kit) adapter. However on Amazon I’ve seen MFI certified Lighting to USB-C cables.
My question is can I use one of these MFI certified Lightning to USB-C cables to directly plug into the Mojo 2’s USB-C port? I think it would be a much wider setup with one less interconnect.
Thanks for any advice
Nicko
mjw
2
My experience with the original Mojo and a certified OTG micro USB to Lightning cable was disappointing, and I ended up buying the Camera Adapter.
However, there appears to be much more choice with USB C, so I would give it a go, but use a familiar brand if possible. Nowadays I use a Poly.
Nick, as I recall a normal cable like this will not work with the iPhone. You need an OTG (on the go) type Lightning to USB cable. I am no expert on OTG, so you may have to look into it. I bought the one below based on one of Darko’s posts and it works for me with the Mojo. This one is from China so it took a bit of time, but I see some others out there now. [Fixed the link.]
I have the Mojo 1 and it does not need the CCK when connecting to an iPhone X, 12, SE or iPad.
It does however need the CCK when connecting to my iPhone 13.
All are one the latest firmware so have no idea what makes the 13 not accept a connection without the CCK. Have w ticket open with Apple and they’re looking into it.
I know you asked about Lightning to UBC C, but thought I should share my experience.
My gut feeling tells me you’ll be fine without the CCK as long as you get an OTG cable meant for data transfer.
You need a special type of cable for that connection to work, in addition to the FiiO one already mentioned, ddHifi also make suitable ones. I have this one myself for connecting iPhoneX to Mojo2: ddHifi MFi06S | FiiO-Shop (also sold elsewhere in case you’re not located in EU)
Jim, the advert for this talks a lot about power and does not mention OTG, unless I missed it somewhere. I have my doubts, and yes, let us know if it works. Thanks.
It talks about data transfer rates. It’s the same as RBO referenced, just a different brand name. If it doesn’t work, I’ll drop it off at the UPS Store two blocks from my house. Amazon makes it incredibly easy to return things.
EDIT: Cable did not work with my iPhone 11 Pro Max. It’s on the way back to Amazon. I’ll continue to use the Apple camera adapter. Not a problem with iPhone in one pocket and Mojo 2 in the other.
