How to change volume MOON 280D from the roon application? I cannot change the volume level in the settings. It’s always 0. In earlier versions of the software everything worked with standard settings. Please help me
I’ve seen someone with a similar issue with a Moon Ace. Try rebooting your Roon Core and the 280D (unplugging the DAC).
See if that helps.
Cheers, Greg
Hi Greg,
Thank you very much for help. I updated to the latest version of ROON Core on the Qnap HS-453DX NAS and it was back in order.
Healthy Easter
Marek (Poland)
