Did you try 48khz?
This is a bluetoooth adapter not airplay adapter. Roon sees it as a sound card so it it works natively via Roon Advanced Audio Transport.
no i did not
yes it is, but the point is to make it work with airplay.
You can get the native sample rate when you connect the bluetooth usb unit directly to roon (or via roon bridge). If itās 48khz then you can try that (or you can just try that directly)
software conversion plugin in alsa has to be enabled
cat /etc/asound.conf
pcm.!default {
type plug
slave.pcm {
type hw
card 1 # for headphone, turn 1 to 0
device 0
ctl.!default {
type hw
One of my customers discovered that the USB Bluetooth Adapter, ZEXMTE Bluetooth 5.2 Audio Adapter for Bluetooth Headphones/Speakers works fine with bluetooth in a Raspberry Pi with installed Roon Bridge.
I have not tested but as it behaves as a normal USB Audiointerface it should also work with Mac and Win.
It has best audio quality you can currently get with Bluetooth (APTX-HD, 24/96)
It works like a USB Class2 audio device and therefore is plug and play.
Best DrCWO
Hi all! I wanted to signalize some options for people like me who boil at the thought of using redundant hardware to bypass (what looks like) an arbitrary software limitation in Roon. After all, Roon on Mac and PC will play music just fine using the machineās built-in Bluetooth, so I donāt see why Roon Core / Bridge on Linux should not be allowed to do that.
First of all, thereās the minimal solution using BlueALSA. I run Roon on an Ubuntu laptop, so I wanted to mess as little as possible with my ALSA config, lest it confuses the PipeWire audio server running on top. The solution I came up with is:
Use snd-aloop to create a virtual HW loopback device.
$ sudo modprobe snd-aloop
You will see two new āLoopbackā devices appear in Roon, enable and select the first one. (Roon does not give you the ALSA device numbers, but the first one should be device 0.) -
Change the PipeWire profile of your loopback device to Pro Audio. This can be done in
pavucontrolin the āConfigurationā tab. Note thatpavucontrolis also not very verbose with device names, so you need to guess which of the āBuilt-in Audiosā is a hardware sound card and which one is the loopback device. In my case, the one on the bottom of the list was the loopback. -
In PipeWire, Connect the loopback device 1 (not 0!) to your Bluetooth speaker / headphone and enjoy! You can do this with CLI or in a patchbay program of your choice. I used
qjackctlsince I already had it installed (see a screenshot below of how it looks).
It can be grouped. But I have not tested, if it is in sync with other members of the group. I can try it next week. I could imagine, there is a slight delay on the bluetooth enabled speaker/headphone due to the bluetooth transmissionā¦
Did you ever try this Christopher?
I just got a JBL Charge 5 for camping, and it meets those needs perfectly, but when I try grouping it (via my phone as an endpoint) thereās a decent delay between the networked RAAT endpoints and the JBL. As far as I can tell this is solely due to the additional bluetooth transmission, if I include my phone in a group using the connected speakers it remains in-sync.
I suspect thereās no fix, and it wasnāt my intended use-case for the JBL, but if thereās a way to make it work then a portable endpoint would be pretty handy during parties.
Set a group zone delay, try different values!
Edit: screenshot is dutch, it the āZone groepering vertragingā, value in milliseconds. Try 1000 to start with.
Sorry I have not tried it, as there is currently no need anymore on my setup to use bluetooth.
(I used this to play audiobooks to my bluetooth in-ears back then. But now I am directly listening from audible and have my in-ears connected to my phone).
Great idea @jmvdv, although I suspect to work correctly Iād now need to set a delay for every other speaker? (i.e. all my speakers are in-sync (Iāve tried up to 5 at once) except for my phoneās bluetooth JBL which is delayed). Iāll try setting all of the others to 100ms delay and see what happens ![]()
Looks like that does the job! Requires about 125ms delay on every non-bluetooth speaker (in my case at least). Need to do a bit more testing but certainly resolves the issue sufficiently for occasional portable use during a party.
And thanks @jmvdv, Iād messed with the resync delay setting (which is for a different purpose and was obviously unsuccessful) but hadnāt found the group delay setting in the advanced audio options.
