What is the flow control setting in the managed switch?
tried it with both flow control enabled and disabled; no difference.
Hi Marco,
My Brooklyn Dac +, has the same issue with 24 bit recordings - it works fine with standard resolution and dsd - switching MQA On seems to solve the problem.
For now I can only listen to 24 bit recordings with MQA filter - I tried the Dac with 2 different PCs, before contacting Mytek who acknowledged the issue and informed me that it will be dealt with via Firmware update.
Robert,
Looks like you’re talking about a different issue than the one from this topic, but FYI: I had the same problem as yours with the Brooklyn DAC+. It seems to have been solved with the latest firmware v1.22.
