Hi,
i powered my DAC+ with the SOtM - sPS-500 for several month.
Two weeks ago i changed the powering. I started to use the SBooster BOTW P&P Eco MKII 12V.
Since a few days, the powering with the external psu isn´t able anymore.
I changed to KECES DC116 without any success. The reconnection with the sPS-500 also failed…
Only powering with the 220V power cable, using then the internal power section, still works.
I fear that something inside electronic of the DAC+ is broken…
As I read in several forums, the SBooster, like other psu, is recommended for the DAC+.
I compared teh technical data of the devices and i see that my SBooster and my KECES delivers 3A. The sPS-500 delivers 5A.
Maybe the powering with SBooster was too weak and damaged the electronic… I wrote to the support of mytek, but didn´t get an answer.
Do you have any experiences with the DAC+ and PSU or do you know the problem and what would you do ? I think i get better sound quality with external psu and wanted the full functionality of using external psu back.
Best regards mike
