Could be. What is the output of uname -m?
x86_64 is the output
Perhaps try this:
uname -m
sudo ./roonserver-installer-linuxx64.sh
And send us the output of both commands. Unless I’m missing something obvious, the installer script will not output the “This package is intended for x64 platforms.” message if uname -m is x86_64 (relevant code below):
ARCH=x64
MACHINE_ARCH=`uname -m`
OK=0
# Check for proper architecture
case "$MACHINE_ARCH" in
x86_64*)
if [ x$ARCH = xx64 ]; then OK=1; fi
i686*)
if [ x$ARCH = xx86 ]; then OK=1; fi
esac
if [ x$OK != x1 ]; then
echo ""
echo -e "${COL_RED}${COL_BLOLD}Error:${COL_RESET} This package is intended for $ARCH platforms. It is not compatible with your machine. Exiting."
echo ""
exit 3
fi
I think with all my aborted attempts at this a fresh install of Debian is in order - it doesn’t take long - thanks very much for persevering with a ADD patient
I will report back
Yes I’ve looked at that part of the script - please see my other reply to you
At long last we have SUCCESS - thanks to you and everyone else who contributed - what a great forum
