Network configuration issues preventing ARC connection (ref#K0V5A4)
Network Setup
· My only router was provided by my ISP
ARC Status
· ARC is *Not Ready*
Roon Error Code
· The ARC settings page says "Not Ready," but I can still connect to ARC via cellular data. I'm having another problem.
"ipv4_connectivity": {"status":"NetworkError","status_code":504,"error":"error: Error: ETIMEDOUT, response code: undefined, body: undefined connected? undefined"},
"external_ip": {"actual_external_ip":"31.aaa.bbb.ccc","actual_external_ipv6":"null","router_external_ip":"null"},
"natpmp_autoconfig": {"status":"NotFound"},
"upnp_autoconfig": {"server_ip":"192.168.1.254","found_upnp":true,"error":"Did not find UPnP service with WANIPConnection on network"}
Standard bt/EE router
Hi @Stephen_Page,
British Telecom has implemented carrier-grade network address translation on some of their residential-tier accounts.
This might not be the case for your account - I’d first try to enable UPnP. On most BT Hubs, this is under Advanced Settings >Firewall > UPnP. Make sure both “UPnP” is enabled.
Alternatively, you can set a manual port forwarding rule in the router firmware. This should be a TCP protocol rule pointing to the IP address and port listed in Roon Settings → ARC.
A third option is to bypass port forwarding entirely by installing Tailscale alongside Roon and ARC on your server and phone. Here are instructions relevant to your RoonServer instance:
Please let us know if this helps.
