I purchased a Ultrarendu second hand. It’s running the latest software and I could add it as a Roon Ready device in Roon. Also my Denafrips Pontus II is showing up. When I play a song everything seems fine, but there is no sound. Also the lights on my Denarfrips Iris and Pontus are not switching to the right bitrate etc.
Could anyone please point me in te right direction? Tried all kind of things, but it doesn’t work.
Thanks so much for your help!
Jochem
AceRimmer
(Smoke me a kipper, I'll be back for breakfast!)
2
How is it connected to the Pontus?
Is that particular output the one that is selected in the uR software as the output?
Which you visit and set by it’s web UI
It’s connected via USB, which is also is selected in de uR software. When I run DAC diagnostics in de web UI of the uR, the Denafrips is also regogniced. I also tried Spotify connect. No sound either.
AceRimmer
4
Might sound obvious but it’s proven to be the case before…have you tried a different USB cable as it sounds like the Pontus is not getting any data from the uR at all.
Double check the uR app switcher to be sure Roon is active and not AirPlay or Spotify.
And check Roon audio settings and be sure the uR is enabled for Roon Ready and not AirPlay.
And be sure the input on the Pontus is set to USB.
Input of the Pontus is detected automatically. But I’ll check tomorrow if bypassing the Iris DDC maybe works. And sometimes checking it with a fresh pair of eyes is the only thing needed.
Otherwise I think buying another streamer is the only option.
I have a Innuos Zen Mini as my Roon Core and I have found with my Denfrips Ares that I have had to restart my Innuos to get sound. Not sure why but I have had to do this a few times .
Its the only dac Ive had to do this with and I suspect its the Pontus thats not making the correct handshake to play the music.
Try REMOVING your DAC from the chain in Settings/Audio. Roon may be “conflicted.” Roon will KNOW of course that there is a DAC involved. For example, in my settings I did not add my Tambaqui DAC. Because the Tambaqui is also a Roon Ready network streamer it has IT’S OWN end point. So try reconfiguring it by removing the DAC.Maybe this screenshot can be helpful… I suggest this only because I know enough about computers to know they do not like conflict. In my case, BOTH my Sonore Rendu streamer is connected to my network, AS IS my Tambaqui DAC which is a stand alone network streamer as well as a DAC. When combined in Setup, perhaps it is creating a conflict. Roon will see the USB cable coming out from your Sonore Rendu so sb unnecessary to drop in your DAC. It should play just fine .
Wow, thanks for all the advice! After a good night of sleep I checked everything again and restarted the DAC. Then it worked! Somewhere in the process I plugged the USB-cable in the DAC, but forgot to set it to usb. Now the Denafrips Iris is shown indeed. Again, thanks so much for all the help! Now time for some music! This one is on heavy rotation: Open Qobuz
