I’m going to start documenting this for my own notes. I don’t often use ARC because some versions work and some don’t and I don’t really have time to find out in the car. So, I’m going to make a stronger effort to document each version (before I leave the house).
This has worked on previous versions.
Core: 1216
ARC: 149
Split Tunnel:
Local: No (Poor Connection)
Qobuz: Yes
Tidal: Yes
Full Tunnel:
Local: Yes
Qobuz: No (Poor Connection)
Tidal: Yes
Same as previous report
Core: 1228
ARC: 159
Split Tunnel:
Qobuz: Yes
Tidal: Yes
Full Tunnel:
Local: Yes
Tidal: Yes
Core: 1237
ARC: 161
Split Tunnel:
Qobuz: Yes
Tidal: Yes
Full Tunnel:
Local: Yes
Tidal: Yes
Core: 1268
ARC: 173
This combination won’t draw the full home page and is unusable. I’ve had various levels of failure this time:
- Get to the “select profile screen” and it animates a “click” but won’t move off the screen.
- Tells me my Core is only accessible remotely after logging in and won’t move forward.
- Shows the “recently played” at top of home screen then knight riders and eventually says “poor connection retry” will not draw anything on home page.
Using the “recently played” menu I can play that stuff so here are some results:
Split Tunnel:
Didn’t test
Full Tunnel:
Local: Yes
Tidal: Yes
You’all want a profile and access to my VPN so you can test this? It’s really nothing special. I’m confused why this stopped working and no attention to get it working as happened. Thank you.
