Ok Thank you! About the ethernet cable, how much should I spend? I know about the snake oil, but I’m using the cheapest cables I found, I think I should upgrade them…
If they meet the ISO/IEC11801, TIA/EIA 568B Category 5E standards and are ETL/UL or CSA/UL approved, they’ll be fine. This should be printed on the side of the cable. I prefer non-booted/ moulded unshielded connectors.
Bill_Janssen
(now wearing snowshoes on my asymmetrical isolation feet)
#5
I’m pretty happy with Amazon Basics cables for everything. But if you feel the need for more quality, Blue Jeans Cable does a nice job.
