@support,
The Nucleus will not see the USB C port where my Wadia 121 DAC is connected.
It is not clear to me what operating system the Wadia DAC uses, but it does have a USB B input which is wired to the Nucleus.
@support,
The USB-C port on the Nucleus is currently not supported. The docs should mention this somewhere.
Thunderbolt port
Currently not active. May become active in a future firmware update.
I guess not everyone will associate Thunderbolt and USB-C as one an the same connector.
So if the USB C port is not active, where/what must you use yo connect the DAC? My DAC has 5 different inputs, but not Ethernet or HDMI.
Use one of the USB ports on the Nucleus. A traditional USB-A to USB-B cable should do the trick. Something like this:
