I have an oral B / Braun electric toothbrush.
I have been noticing that it doesn’t sound as powerful when I have been cleaning my teeth and my teeth sometimes don’t have that beautiful shine that I come to expect when I look in the mirror each morning.
I’m wondering whether a better power supply might improve matters as currently I’m just using the power supply that came with the product.
Has anyone had any success with aftermarket power supplies with the electric toothbrushes?
I believe that clean power is needed for clean, bright and shiny teeth. As most clean power is provided by batteries, try adding more/stronger batteries?
I was also wondering lately how the way power and batteries are produced (ecological foot print) may have an influence too. Maybe we need more green power (climate compensated batteries ftw) instead for better results?
Whatever you do, don’t bring your non-audiophile toothbrush anywhere near your audiophile router. We don’t want plaque getting between the ones and zeroes!
John, it’s obvious. You need a PS Audio Powerplant 3 to convert the mains to DC and then regenerate it to AC to get optimally ordered electrons to charge your toothbrush battery and give a perfect shine to your pearly whites.
While a 240 V source may help. I recommend you find a 3 phase 440 V source. Wrap one hot around you waist (insulation removed. Wrap the other hot around the toothbrush from end to end (insulation removed). This will deliver the white you are looking for in just a few minutes of brushing. See ya soon.
Definitely not a linear power supply. Rather, a circular power supply. Because the best pace, rhythm, and timing comes from circular brushing.
And a power supply with a lithium ion battery. While not fluoride, lithium and fluoride do share some chemical properties, as they are from the same Period 2 on the periodic table. Feed your enamel with that clean ionic goodness.
You just need a well designed electric toothbrush that is immune to crappy power. But do not trust the marketing, you need to blind test them. So take at least 2 snakes, blind them, and wash them. One snake will ask you “what kind of toothpaste you use?” and the other will just try to bite you. I have done that again and again and always the blue toothbrush has better power.
I’m a dentist, and I’ve always found that the gentle stroking action from my right hand used manually is much more preferable to the vibrations from an electric device
