Good afternoon:
Yesterday I was making changes with different Hq Player filters. Suddenly, the connection with Roon was lost. I’ve tried Squeeze with Roon and it works perfectly, but when I try to switch to Hq Player, Roon seems recognizes it and it looks like the track is going to start, but it doesn’t. I have tried uninstalling Hq Player in Roon and reinstalling, refresh in Antipodes. It does not work. Any advice?.
Thank you.
Kind regards
Reboot your dac, and then restart HQplayer .
I have tried it but it doesn’t work. Can I uninstall Hq Player key and reload the file? Anything else?
Can you try using HQPlayer Client iso Roon. Make sure tostop Roon completely so it does not keep HQplayer connected.
There is no way. Only works Roon and Roon with Squeezlite. When I put Hq Player with Roon server it seems to work, but the play cursor does not advance.
Good afternoon: I just wrote to Jussi because I saw that they sent me a temporary key file 4.34.0.
Perhaps it has expired.
I’m waiting his response.
Thanks.
It is fixed. It was a speakers configuration problem. After quite a few emails and Jussi’s patience, the music plays again.
Thank you
