The titles of the songs on the album appear in the genres. Yet they are not in any album tags on my PC. I have this problem on several albums. Is this normal?
yes
Of course I checked my tags with tag Editor and nothing. I inspected all tag fields (including “Category”) and everything is OK. It is on import that it implements the song title as a genre.
No, it’s not, and I’m not sure what is going on. You say you have the problem on “several” albums - I assume that this means that not all albums show up like this?
What happens if you (as a test) turn off the “Use genres extracted from file tags” in Settings > Library > Import settings? Do the titles still show up as genres?
Indeed by doing what you say (turn off the “Use genres extracted from file tags”) the Titles disappear from the genres but then all my tags disappear too !!! And I don’t want to. What is curious is that this happens on the albums where I created a personal tag “Chanson Française” which does not exist in roon. I’m thinking of the “ç”
@Frederic_Malbrel … can you post the file tags as seen by roon for one of the album tracks where track titles show up as genres? Maybe that gives an idea what goes on. You find this info via the three dot menu after each, see example below.
Depending on the number of tags present, you may have to take two or more screenshots in step (4) – and scroll down in between to capture all the info.
I found the answer. I’m using Music Brainz and an extension tag the “Style” field which in Roon is imported as a genre. And it was in style that Music Brainz wrote the title…
