If you Get Info on the Roon app in OSX, you see a checkbox for open in low resolution. Does that improve sound quality slightly or anything like that?
That only has to do with video resolution. Not audio
Thanks. I tried it and it looked bad so I unchecked it.
I like the new avatar.
