First, a big thank you to @Darthspader for building Rabbit Hole (his thread). It’s become the way I listen every day, and none of what follows would exist without the work he put into it. The discovery engine and the Roon integration are excellent, and it’s clear a lot of care went into them.
I’m starting a separate thread for my work so I don’t clutter his. Some of what I’ve changed:
Lyrion styled to match Roon, plus extra Now Playing details
HQPlayer output shown under the album art
A waveform seek bar on both players
Star ratings under the art
Selectable themes
Theme fixes
An Unraid template
@Darthspader, I also owe you an apology for the pile of PRs. I’ve opened 25, and 23 are still sitting in your queue. That’s a lot to land on one developer, and I should have talked to you before sending them all. If they’re more noise than help, say the word and I’ll close them.
I’d like to share my version on GitHub so other people can use it. It’s a fork of your repo under the Apache 2.0 license. I’ll keep your license, notices and credit intact, list what I changed, and make it clear that it’s my fork and not your project. I hope you don’t mind. If you’d rather I handle it differently, tell me and I will.
Finally, I’ve changed a lot, and I fully understand if you don’t want to take Rabbit Hole in my direction. It’s your project and your vision. Take whatever is useful, ignore the rest, and I’ll keep my fork in sync with yours rather than the other way around.
Thanks again for building this.
