This may have been asked before but I haven’t found it. Is there a way to make radio play less loud? The difference in volume between my own music/Qobuz and the radio stations I regularly listen to is quite large so that a switch to Radio always has me desperately searching for the remote to turn down the volume.
Not directly there isn’t.
But have you tried using volume levelling for “unknown loudness”?
https://kb.roonlabs.com/Volume_Leveling
Thanks Brian, I did not know that and I have enabled it now. Hope it works.
It works. Thanks again.
