I just received a Chord Qutest, and having read suggestions I picked up a Curious USB cable to go with it. I’m trying to use my Rasberry Pi as the streamer going into the Qutest via the Curious USB, however whenever I plug in the Curious USB it won’t show up as a device in Roon most of the time. Occasionally it shows up momentarily but then has difficulty connecting. However, when I use the USB that came with the Qutest it works fine. Additionally, if I plug the Curious into my MacBook pro and then to the Qutest, the Qutest shows up immediately, so it’s something to with the Rasberry Pi in the chain.
I would suggest you do basic resistance checks to make sure there are not any wiring errors/issues with the Curious cables. If purchased new return them to the vendor for a refund or exchange…
AceRimmer
("I’m not just a hero; I’m a legend!")
6
I owned a Qutest a few months back.
I had zero problems with any USB cable I tried connecting to a Sonore Ultrarendu.
This included el cheapo printer cable, Audioquest Carbon, Audioquest Diamond, Pangea, Straight Wire etc.
I’ve had a Qutest for a couple of years now and have had no issues with a couple of usb cables, a couple of laptops > Qutest, servers > Qutest and network transports > Qutest all over USB… As I understand it, the Qutest has quite the galvanic isolation and secret sauce to reduce noise ingress thanks to Rob Watts… I would look to the cable first then the RPi transport…
The cable works immediately when connected to my Mac Book Pro, yet definitely seems to not work when plugged into the pi. I’ve also tried to play through Spotify using RoPiee XL and with the Curious cable, no sound, but it recognizes the RoPiee (since Spotify Connect doesn’t need to see a DAC) if I change cables it works, most of the time.
Not the outcome that I was hoping for but alas Curious got back to me and their assessment is that their cable is just incompatible with the RPi platform.
While at first I was having intermittent issues with the stock cable as well, I re loaded RoPieee and it I consistently get a good connection with the stock cable. So, yeah, does seem like the cable doesn’t work with Rasberry Pi. I have an email out to Curious, but sounds like they’ll tell me the same thing as you @Anthony_B .
Alex yes mine won’t work so I will use a audioquest coffee usb actually sounds better with the pi with ropieee than just using intel nuc and curious directly to Hegel h590 dac
I just skimmed Curious’ website and read “Our Story”.
Purely empirical cable design without any technical scrutiny - and people wonder about failing USB handshaking? And off topic:
If you use their XLR balanced cables, sporting silver plated contacts, make sure you regularly re-plug the connectors to clean off the buildup of tarnish.
Hi Andy, just saw your post, no Volumio is my least favourite platform.
I predominately use only ropieee and occasionally for fun I will build an LMS server.
I have the curious cables were they need to be (Innuos MK3 mini server, Innuos PSU, into an OPPO HA-1, everything sounds very good so I have stopped tinkering.
