I would like to assemble a Raspberry Pi 4 using a Hifiberry Digi + Pro HAT and a 7β touch screen. Do you have any recommendations concerning a decent case for this type of build? The case should fully house the Raspberry and the DAC and not be a barebone case with a display attached.
Audiophonics.fr sell this:
Link
I imagine your HAT should fit under the cover though you might need to do the additional drilling to access connectors. If it doesnβt fit there is an additional cover for the same case that provides more room.
