Very strange and it’s showing two different MAC addresses in the Synology DHCP server?
Also a possibility is that one of the services is turned on requires WiFi access ike Airplay so may have turned it on) but this is pure conjecture from my side as I have not used Ropieee in some time.
Mark, if it has 2 different MAC addresses it is most likely using Ethernet and WiFi, even if you have not set this up. If not 2 MAC addresses (which I doubt) the maybe 1 will disappear in time.
A DHCP static address will only impact one of those and the other one will continue to get a dynamic DHCP address.
Personally I tend to give all my streamers static DHCP addresses so I can easily find them if I need to login etc
When I first got my Nucleus, it too showed up twice in the Finder.
Until the experts came to my rescue by recommending Static DHCP Reservation.
Everything seems to be working brilliantly. So pleased I added this endpoint. Just want to be sure I’m making the most of the way it’s supposed to work.
Just a thought, are both ip addresses active? DHCP, on some routers, will display previously used ip addresses as being assigned to a device until it gets reused.
I’m not sure if DHCP on the Synology operates the same way but it’s worth checking and avoiding a “goose chase.”
If it was my system, I would perform all ip address allocation from my Router’s DHCP as it is the “hub” of my home network. The network would normally have one DHCP active, that of the router, to avoid misallocation and ip allocation clashes.
I second this, using IP reservations and not setting static IP on the devices. I have seen a few people have to go through the headache of trying to reset the network settings on all their devices when switching to a new router.
The ethernet network connections look fine, without checking the individual items I can’t make an educated comment however, it looks like in should work.
If you experience any problems post the details here for further suggestions.
I see no downsides of the set-up and second @PixelPopper 's suggestion if you experience any anomalies or issues to come back and post them. I would not expect any issues, though.
None whatsoever. Every single permanent device in my house has a DHCP reservation. I often set one up before turning a product on, if the MAC address is printed on the outside of the product somewhere.
