At boot time there are some momentary higher consumption peaks.
UP Squared is good for running HQPlayer OS with some basic PCM upsampling and such. It’s a bit more powerful. With NAA OS it has the problem of two ethernet ports. So if you’d like to use it for NAA functionality, HQPlayer OS is better for UP Squared.
Typical symptoms if you run out of power are device reboots or USB port falling off. You will certainly notice…
I also got their Oor headphone amplifier. It’s a very nice one! Now I just need to get a second Hypsos at some point for powering the Oor . Now the Oor is running off the stock SMPS power brick.
I have a Hypsos for my etherRegen and I can say it’s both for features and soundquality. I had a Farad Super3 before the Hypsos and the Hypsos gives a better SQ than the Farad Super3.
