Remove USB product under audio settings
With my desktop setup I am currently using iBasso D16:
Before that iBasso DC07-Pro.
The USB driver for iBasso DC07-Pro has been removed and a reboot has been done. Than installed the USB driver for iBasso D16
But the settings for iBasso DC07-Pro still showup under “Roon Audio Settings”
Any suggestions how to fix that?
Torben
Have you tried enabling it the Dc07? What does Roon do?
Have you tried the “refresh” button in that “This PC” section?
There could be remnants of the device or drivers still in your system? Is there anything in windows settings apps & features or task manager services/processes that is still running?
Is the PC your server or just a client? If it is a client you might try, restart, reboot, and maybe re-install of the client software?
Have a look:
No impact
Have been looking under apps, drivers etc. but can’t find anything.
On a PC (client). Restart, reboot … no impact.
Torben
Have removed the driver again and than reinstalled Roon SW on the PC. Than the iBasso D16 driver.
But the DC07-PRO is stille there :frowning:
Torben
When you removed the device did you go to device manager and uninstall? If so did you check the box to remove drivers? You may need to re-install/reconnect the device and try again?
In device manager check other section (like system devices, Audio inputs and outputs, USB section, sound controllers, etc) to see if there are any other entries for the device?
Another thing to try, this might be a stretch and a PITA, but you could try deleting the USB entries in Windows device manager and letting it re-install them all. I would first try telling it ti “scan for hardware changes”
Right click on the USB section headers:
You would then need to reinstall the drivers for the new device or any other devices that need drivers.
I have done this in the past when the USB buses, hubs, and hosts did not play nice due to leftover “drivers” and chaff which caused flakiness with USB devices.
I think the only way it stays in Roon Audio is because there is still an “active” connection? As in Roon still sees something on the PC that represents the device. So you need to find whatever it is and shut it down or delete it.
Thanks for all your suggestions :slight_smile:
When I uninstall the IBasso USB drivers and reboot, I still have this in Roon
But there is nothing in the device manager.
After installing iBasso D16 USB driver I am back here again:
Never had this kind of problem before.
Torben
