RGB matrix led display
Hi all,
I’ve created a python code to send the art of the current album playing to a RGB led display. The result is impressive. I don’t have strong coding skills, but I think this is a quite easy project!
20210804_181454_1_1
It’s all based on this post, so check this first for the hardware and to set up the screen; https://www.reddit.com/r/raspberry_pi/comments/ombwwg/my_64x64_rgb_led_matrix_album_art_display_pi_3b/?utm_source=share&utm_medium=web2x&context=3
I’ve created a Python code to get the art and track details from the web controller extension, so first you need to install this. (somebody with more skills could try to get this from the Roon API)
I’ve uploaded the code here: GitHub - kajuku87/roontomatrix
Hope you find this useful!
This is exactly what I was looking for! Thank you! I will be replicating this later in the week once everything arrives.
Really keen to get this going. I have setup the hardware and managed to run both the server and client on th rPi no problem - I can send text, images to the display however i am having problems running the python code you link.
to successfully start my server i type the following from the folder that the ft-server is in:
sudo ./ft-server --led-gpio-mapping=adafruit-hat-pwm --led-slowdown-gpio=2 --led-rows=64 --led-cols=64 --led-show-refresh —led-brightness=50
I modified the line in your code to reflect this (as it didnt have = symbols in there for some reasson. The 3rd line of loadserver.py now looks like:
process = subprocess.Popen([“sudo ./ft-server --led-gpio-mapping=adafruit-hat-pwm --led-slowdown-gpio=2 --led-rows=64 --led-cols=64 --led-brightness=50”],stdout=subprocess.PIPE,stdin=subprocess.PIPE,encoding=“utf8”)
I have both python (2.7.16) and python3 (3.7.3) installed and get all sorts off errors depending upon what python i use and whether i’m running main, loadserver or getart scripts
errors relating to either ‘encoding=uft8’ or ‘file not found problems’ or if running getart problems relating to the selenium module not being seen (it is installed) or no module named ‘request’
I don’t have too much experience with Python. Can you tell me exactly what version and whether 2 or 3 is to be used. Also what dependancies do i need to install?
The error messages are not helping me and this is turning into quite an exercise.
I got the hardware and flaschen server - client going no problem
Any help really appreciate it
Thanks!!
I Jonathan, I used Python 3. It’s hard form me to help you from here as I’m not an expert on python either.
What I suggest you is going by parts.
I used the Thonny tool included in the raspberry OS to debug the code of the different modules. I would start with the loadserver.py. Make sure you have an image on the images subfolder and try to run the code line by line. This should help you identify if you have any dependency missing.
I hope this helps you
20220920_211427_1
Its pretty cool! I added 3 more screens to do a 128x128 matrix and made the backlight of the self match the dominant color of the album
neat. update your python code to show how you worked with 128x128. I may try this on arduino instead RBP is just overkill with a file system operating system always get corrupted.
I’d guess there isn’t enough processing power in an Arduino but good luck!
I mitigated the sd card corruption issue by simply making the file system read only after setting everything up. No issues so far, I just power everything on and off :man_shrugging:
wrong. i just did it, using Circuit Python. 4x 64 displays (128). Works great. wrote a roon extension for it as well. i’ll post something aobut it soon.
wow nice! I’m excited to see that! :slight_smile:
Hey @narkotic ,wondering the status of extension you mentioned?
Keeping it private for now as it has some bugs, but it’s pretty neat. I want to change it completely to be more of a polling interface where I can set the roon plugin to “send” alerts to the display to 1. Blank it 2. show song details vs. album art 3. Revert to a word clock I wrote in circuit python that shows when music isn’t playing. Right now the plugin simply dumps album art scaled to 100x100 and the display (python) polls the network for a image and it’s there it displays it. The roon plugin deletes the image if music is stopped/paused so the clock sees an image not being in the folder so it reverts back to being a clock…
