Did you reboot everything and try again? Sadly, this is sometimes necessary.
I donât have an answer for you but Iâm curious how, independent of rooExtend / rooDial, you control volume on the zone youâre working with.
Youâre using your NAD as a pre, and thatâs the Roon (BluOS) zone. Is that zone set to âUse Device Volumeâ and do you normally adjust your Preâs volume? Or does your amp have a volume that you typically adjust?
Iâm wondering if your pre should be, or is treated like, line out and should be fixed in which case rooDial isnât going to work for you in that zone.
Just a guess.
Thanks, I did not yet in case there is something to be learned. Frankly it was quite scary and if this happens again I will probably have to find another solution, I donât want to risk my speakers nor wake up the whole building
@gTunes thanks for your inputs, I probably was not clear enough, the system worked perfectly with rooDial in the past few days and the volume control was reasonable, thatâs why I was fully taken by surprise today
I understand. I do think itâs worth considering what I wrote about volume control. One scenario that could explain what youâre seeing is that your setup is pre â amp and that rooDial is controlling the preâs output but you also use a remote or a dial on the amp itself to control its output. If in between the âtime it workedâ and now, you or someone increased the volume on the amp, that could explain exactly what youâre seeing.
But if your amp is fixed and youâre sure that nobody touched it, then my points here donât apply.
I hope you figure this out!
What release did you use. V3.0.x?
There is a bug in the linux driver that I sent to the Linux guys last year but nothing happens until now.
I had to live with it and did a lot of things that this did not happen. As I heared nothing regarding this issue for such a long time I thought my solution was bullet proof. Seems not
Please set up max volume in your device settings to avoid speaker damage. And if it happens again please send the log to info@definiteaudio.de. Maybe I find this final holeâŚ
The work around is to remove batteries. After this it should work as expected.
This is the big fun I have working with free software. Bugs and nobody is responsible for fixes
I am really sorry about that.
Best DrCWO
I experienced exactly the same things. I even blown up the tweeter of one of my B&W 803!
The solution is to remove the batteries of the Microsoft Surface Dial and insert them again.
But that is a temporary solution, as I had the same issue already 5 times since I started using rooDial approx. a month ago.
Now I always turn the knob a little bit anti-clockwise until it reacts, and checks if it is going totally down or only one volume-step. If it turns only one volume-step down, I know that it is safe and that I can turn the volume clockwise to a higher level.
But donât think that 5 minutes later it is still safe, because I already had that 5 minutes later the hell got loose again when I simply wanted to turn the dial a fraction clockwise. To be clear: nothing in the room was changed in between those two volume adjustments. I must admit that the fun of using the rooDial isnât that great any more.
I have put my Raspberry Pi 2W still what closer to the Microsoft Dial in the hope that this will solve the problem, but I am not sure. The distance was approx. 1,5 m. Now it is approx. 1m.
@DrCWO does the same behavior occurs when using a Nuimo? I am hoping to solve this issue with a second hand Nuimo. But the second hands Nuimo are very expensive, and also the price of the license is much higher than of the rooDial. But I have to find a solution, as the price of a tweeter of a B&W 803 is also very high!
I have set now the volume-restrictions in Roon of my Rotel RC-1590 to an acceptable level. I use the extension of Boris Schaedler to handle the volume of the amp. I wiil check if that will safe my tweeters.
No,
this driver issue only occurs with the Surface Dial.
As I canât reproduce it here any more I need to know more details. You use 2W, wireless or with Ethernet? I run ethernet only. What I urgently need is a logfile after this happened and before you put out batteries.
Maybe the reason lies in the WiFi connection in combination with the driver issue. I will set up a Zero 2W and see if I can reproduce the behavior with Zero 2W and WiFi.
I am really sorry to hear about the killed tweeters and will report back If I got an idea of what goes wrong there. I have to handle the driver issue in user space as I donât have the knowledge to build or modify Linux drivers. I tried my best but seems it was not enough
Best DrCWO
The Zero 2 W is fully wireless: No Ethernet-connector and no BT-dongle (yet). That is why I decreased the distance between Dial and Zero 2W to its minimum. It is also not too close to a WiFi Basestation, so it would be satturated. But the WiFi-signal is still good enough.
I have no idea whatâs happening and will let you folks try to figure it out.
@DrCWO - do you think, though, that itâs worth looking at whether either of these users has changed teh âChange volume at playback onlyâ setting to âNoâ? I believe it defaults to âYesâ. Just a thought.
Hi Greg,
I can confirm that the setting âChange volume at playback onlyâ is set to âNoâ, as I also use the Dial when I am watching TV. So Roon is not playing at that moment, but I can still change the volume of the Rotel via the Dial. Up till now I only had the error when playing music via Roon. But on the other hand I seldom watch TV.
Thanks. Will setup a Pi Zero W2 now with WiFi and see if I can reproduce this.
Please think of sending log if the issue occurred againâŚ
@DrCWO ,
Which specific log do you want:
- System Log
- Update Log
- Service Info
All of them or still another?
Kind regards, Frank.
Thanks @DrCWO and @Frank_M for your inputs, that does sound worrying.
On my side I can say that I was running rooExtend on a raspberry 3B+ and at the time I had the issue it was connected via wireless, unfortunately I had rebooted it in the meanwhile so the logs are gone, I have now connected it over Ethernet and I will do so for a couple of days to see if the problem is reproduced in this setup. âChange volume at playback onlyâ is indeed set to âYesâ.
@gTunes sorry for misunderstanding your comment, indeed it would make sense but with the additional information it is pretty clear that this points to another issue, I hope this can be solved soon and I will share any information I can.
I do agree that it looks like another issue. On community support forums, like this one, well intentioned people (like me, usually) who are trying to help, can get in the way of someone making progress. I apologize for popping in and doing that.
Hi @DrCWO,
Whatâs currently the best budget HW for rooDial only?
It can be Ethernet-only device if that changes anything.
If you get a Pi with ARMv8 and wired Ethernet you are future proof.
So get a Pi 2 Mod. B v1.2 or above will be fine.
best DrCWO
Iâve read that adding an action to start a specific radio station is planned (for a long time alreadyâŚ).
When do you plan to introduce that feature? Iâd really appreciate that.
I have a long list of improvements for most of my Roon Extensions. I will work on this list after having published rooHead in Feb. starting with new functionalities for rooDial. You can rely on this
This means no more new Roon Extensions after rooHead but instead working on the open topics
Merry X-mas
DrCWO
