Intel NUC with Ubuntu 22.04
UniFi Dream Machine Pro directly attached to fibre
I’m trying to setup ARC using the manual method, I’ve enabled NAT but Roon still seems to be having a problem.
Do I HAVE to enable UPnP? From the support article, it’s described as either UPnP or manual method (NAT).
Or is my ThreatManagement maybe blocking the IP that Roon is using to check?
Hidden my actual public IP.
"connectivity": {"status":"NetworkError","status_code":504,"error":"error: Error: ETIMEDOUT, response code: undefined, body: undefined connected? undefined"},
"external_ip": {"actual_external_ip":"???.???.???.???","router_external_ip":null},
"natpmp_autoconfig": {"status":"NotFound"},
"upnp_autoconfig": {"status":"NotFound"}
