I’ve experienced connectivity problems with my ROON Arc recently.
ROON Arc Menu Settings on my ROON Core (Apple MacBook Pro) says: Roon has no access to your Roon Core
The diagnostics you’ve provided suggest that UPnP is enabled on your network, but your router is refusing the connection. This is either the result of UPnP not being enabled properly on your router, or settings at the level of your internet service provider.
First, to confirm the issue is not with your local network setup:
Try to enable UPnP/NATPMP in the web administration interface for the router directly upstream from your Core
Try to manually open the port in your router’s port forwarding configuration
Make sure the IP/Port matches the Port listed in Roon → Settings → ARC
Check for any VPNs or Firewalls that might be interfering
Check if your modem is in Bridge mode
If you continue to experience difficulties, we recommend reaching out to your internet service provider and passing along the following questions:
Have you implemented carrier-grade NAT for my account level?
Have you fully implemented IPv6, or do you have IPv4 addresses available?
Can I request a static IPv4 address to support port forwarding?
Are there any ports you have reserved at the ISP level I should be aware of?
I haven’t tried these things, as Roon Arc seems to have fixed itself luckily. Maybe my Router has reset its settings by itself or something, after the Firmware update? All of a sudden I got a good working connection, between Roon Arc and my Roon Core.
