uPnP is on. Here is my wireless router configuration. I have no clue what the port range should be. Roon doesn’t provide one, and the router demands it.
@David_Zweig, it appears you have two networks running in your home, what I surmise is the Verizon-based network with IP address range 192.168.1.nnn and the ASUS-based network using IP address range 192.168.2.nnn. Roon requires all devices to be on the same subnet (the first three sets of address numbers being identical).
It appears that your Roon Server computer is connected to the ASUS-based subnet based on your screenshot above. Given the two networks, UPnP will not work and should be deactivated on both routers. Instead, you need to set up port forwarding in the following manner:
Forward Port 55000 using TCP from the Verizon router to the IP address of the ASUS router.
Modify your ASUS port forwarding rule to be similar to mine (I added a slightly larger port range in case ARC changes the port number). My version of the ASUS admin page does not quite match yours, but it should provide guidance.
Thank you! This is truly helpful Robert. I am not clear how to change the Gateway configuration with Verizon (they don’t make it available under “Settings” but I have a call in to them. I am attaching a schematic of my configuration, but I think you understood if perfectly. I’ll keep you posted when I hear back from my Verizon tech support guy.
We’re assuming that the switch does not need any alterations, yes?
The Verizon subnet is different than the ASUS subnet. You need to look at the the first three sets of numbers (not the last number), if they are different then there are two networks running (two subnets). In this case, there are two subnets:
Verizon: 192.168.1.nnn
ASUS: 192.168.2.nnn
Given the limitations of the Verizon router’s configuration and specifically creating a port forwarding rule, I am not sure what to recommend. It may be worth speaking to a Verizon support representative and ask about creating a port forwarding rule on their router.
ASUS does allow you to configure their AiMesh system into just a WiFi mesh network that would be on the same subnet as the Verizon router, but I am not sure if you lose other capabilities by doing so. I recommend speaking with Verizon first.
@David_Zweig, under your Roon ARC Settings options in the Roon ARC application, if you select “Disconnect from ”, then restart the ARC app and reconnect to your Roon Server, does the Poor Connection error remain?
Try putting Asus into access point / no DHCP server mode and let Verizon handle the IP assignment. Anything that is static configured to use an IP from Asus will need to be in DHCP more or you will otherwise need to manually switch over to the Verizon box.
The port test can ping external servers through the open port - this means Roon on the Mac Mini has line of sight through the unmanaged switch, the Asus router, and the Verizon gateway to our own servers without a NAT layer interfering.
However, this port test in Settings doesn’t actually initiate a downstream connection to the phone, nor does it test the integrity of TCP stream across the pathway. The latter is the problem here, since ARC is timing out after authorizing a session on cellular data.
Try this:
Bypass the switch entirely. If you don’t want to do that, at least try re-arranging the port connections for the Synology one at a time and see if that improves things.
If that’s unsuccessful, try a different port on the switch for the Mac Mini.
IGMP snooping is enabled in the ASUS router.
If none of the above is successful, I recommend installing Tailscale on the Mac Mini and the ARC phone. This is a fairly simple proxy-mesh network based on Wireguard, and it’s our recommended alternative for these situations.
