djnoctis
(Jose Antonio Vilar)
November 19, 2022, 10:47pm
1
Intel NUC 12th Gen on Audiolinux OS
Vodafone DE Vodafone Station
connected to an ASUS RT-AX92U via ETHERNET
ASUS RT-AX92U is connected to a Devolo Magic 2 Powerline
then the Powerline is connected to my Intel NUC where Roon Server is installed
DENAFRIPS ARES II
50 tracks on SDD
Can’t use Roon ARC
I’m getting this error:
“external_ip”: {“actual_external_ip”:“88.aaa.bbb.ccc”,“router_external_ip”:“null”},
“upnp_autoconfig”: {“server_ip”:“192.168.50.1”,“found_upnp”:true,“error”:“<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/\ ” s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/\ “><s:Body><s:Fault>s:ClientUPnPError<UPnPError xmlns="urn:schemas-upnp-org:control-1-0">718ConflictInMappingEntry</s:Fault></s:Body></s:Envelope>”}
Any idea how to solve this?
I have an ASUS RT-AX92U Router and I already tried to port forward the connection but to no avail.
UPDATE:
Opened Port Forwarding and Disabled uPNP on my router
New error appeared!!!
“upnp_autoconfig”: {“status”:“NotFound”}
Hi @djnoctis ,
The above might suggest you have uPnP activated and a port forwarding rule to the same port active at the same time. Try to disable uPnP if you don’t need it and keep the port forwarding rule to the port and IP address of your Roon core.
Hope this solves it.
djnoctis
November 20, 2022, 4:29pm
4
Hi!
I have updated the networking gear and setup details
djnoctis
November 20, 2022, 4:39pm
5
I did this and got a new error.
djnoctis:
So it’s:
Vodafone Station → Asus router → Devolo Powerline → NUC with Roon Server
When I look on the internet I see the Vodafone station is also a router with DHCP and NAT. Do you have it in Bridge Mode so all the traffic is routed directly to the Asus without NAT? If not, you have to also set a port forwarding rule in the Station to the address of the Asus router with the same Roon port.
djnoctis
November 20, 2022, 10:21pm
9
I used LAN ports from the Devolo. It should mesh with the network built by the ASUS Router. I will try the suggestion of @Joost_Hoogland and will let you guys know. Thanks so much!
system
(system)
Closed
January 15, 2023, 9:10pm
11
