Roon Rock on Intel NUC Tiger Canyon NUC11TNHi7 (16GB RAM)
(0) Incoming signal from provider (Coaxial) > (1) Telenet-Router modem model CH8568LG. Wifi disabled. Connected downstream via ethernet > (2) Orbinet 750 series router > ( (3a) NUC Rock via ethernet cable & (3b) iFi Zen Stream receiving signal via Wifi from Orbit Netgear.
My ISP provider is Telenet in Belgium. The Telenet router can unfortunately not be omitted in the system as this possibility is not provided by Telenet. ISP provider also mentions their router/modem cannot be bridged. See screenshot further below for configuration options in Description of Issue for Telenet-Router modem model CH8568LG. I have understood that port forwarding option is something to be manually installed. My guess that my problem has something to do with it, but I am not an expert.
ISP Router > Orbit Netgear 750 (via ethernet) > ifi Zen Stream (via Wifi from Orbit Netgear 750 series)
Orbit Netgear 750 (via ethernet) > Intel NUC Tiger Canyon NUC11TNHi7
Library is currently very small. Tidal only. Just starting with NUC ROCK but planning 15000 Tracks
ROON ARC settings > message: NOT READY Roon ARC will not be able to acces your Roon Core
Diagnostics:
“connectivity”: {“status”:“NetworkError”,“status_code”:502,“error”:“error: Error: connect EHOSTUNREACH 84.aaa.bbb.ccc:55002, response code: undefined, body: undefined”},
“external_ip”: {“actual_external_ip”:“84.aaa.bbb.ccc”,“actual_external_ipv6”:“null”,“router_external_ip”:“null”},
“upnp_autoconfig”: {“server_ip”:“10.0.0.1”,“found_upnp”:true,“error”:“<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/\” s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/\“><s:Body><s:Fault>s:ClientUPnPError<UPnPError xmlns="urn:schemas-upnp-org:control-1-0">718ConflictInMappingEntry</s:Fault></s:Body></s:Envelope>”}
See screenshot Roon
Questions
Please help on making ARC set-up/connect to my system
(1) My NUC Rock has a very different IP address. Should I adopt the NUC Rock IP adress and put 10.00.00.xx
If yes, what are the inputs for the other remaining fields?
(2) Should the IP address from my NUC ROCK be entered in my ISP provider settings from the screenshot below
Screenshot ISP telenet modem/router
There are more fields in the ISP provider screen than in the Roon installation info (which internal and external ports should be filled in and what to do with the remaining fields?)
(3) Should the DMZ field be changed
Thx in advance for support on setting this up, Arie
