My Roon Core is on a HP PC connected to a mesh network System. It will not connect away from home
I am very much a novice so need help. Thanks
Please complete the support template below, and include details of all your network devices, how your core is connected, and the steps taken thus far.
In addition, please share message from Settings > Roon ARC.
<!-- Include your operating system and machine info (Model, CPU, RAM) -‐>
<!-- Write below this line -‐>
<!-- Your network gear (model of routers/switches) and if on WiFi/Ethernet, are you using VP -‐>
<!-- Specify what devices you’re using and their connection types, like USB/HDMI/Chromecast, etc.) -‐>
<!-- Tell us how large your music library is, eg. “30,000 tracks” -‐>
<!-- Tell us about the problem you’re having in as much detail as possible. Screenshots are always appreciated! -‐>
HP Pavilion Wave Desktop PC 600-ao55na
Intel Core i5-6400T
16GB
Integrated Intel HD Graphic
Integrated Bluetooth 4.2 and Wireless LAN 802.11a/b/g/n/ac featuring Dual-band (2.4 GHz and 5.0 GHz) 1 x 1 technology
128 GB PCIe NVMe M.2 Solid State Drive
Microsoft Windows 10 Home (64-bit)
Deco M5 Mesh System connected to BT Smart Hub
Wi-Fi 5
IEEE 802.11ac/n/a 5 GHz
IEEE 802.11n/b/g 2.4 GHz
TP-Link Mesh Technology
Optional Ethernet backhaul work together to link Deco units to provide seamless coverage
Access Point Mode
Qualcomm 717 MHz Quad-core CPU
WPA-Personal
WPA2-Personal
Port Forwarding
UPnP
TP-Link
ipad
Samsung S9
Naim Unit Atom
Several Sonos Speakers
Do not have NAS - Roon connected to Itunes Library plus hard Drive of HP.
Estimated 30000 tracks?
It looks like you may have a multiple NAT setup. To confirm this, please share message from Settings > Roon ARC. Edit the external IP to 123.123.xxx.xxx before posting.
As requested:
"connectivity": {"status":"NetworkError","status_code":504,"error":"error: Error: ETIMEDOUT, response code: undefined, body: undefined connected? undefined"},
"external_ip": {"actual_external_ip":"81.159.x.x","router_external_ip":null},
"natpmp_autoconfig": {"status":"NotFound"},
"upnp_autoconfig": {"server_ip":"192.168.1.254","found_upnp":true,"error":"Did not find UPnP service with WANIPConnection on network"}
Did you see my last reply?
The message indicates that you have a double layer of NAT in the local network or with your service provider.
Please see the Multiple NAT section in this guide.
Hello Martin.
As far as I can see I have to to change my BT Smart Hub 2 to bridge or modem mode. Is that correct?
However I have trawled the internet and cannot find a method to do this.
Unfortunately, you can’t do this with the BT Smart Hub. Therefore, you need to setup port forwarding in the Smart Hub and the Deco.
Essentially, something like this…
Internet (81.159.xxx.xxx) → Smart Hub (192.168.0.1) → Deco (192.168.1.1)
…so setup port forwarding in the Smart Hub to 192.168.1.1 (if this is the IP of the Deco) and in the Deco, either use UPnP or port forward to 192.168.1.254 (or whatever is the IP of your core) using port from Settings > Roon ARC.
