Roon at home and at work location
Hi I have Roon at home. How can I enjoy Roon at my office 50 kilometers from home? Is that at all possible? If not that is an omission. I had my Apple Music everywhere I went. With ARC I have it in the car but what about my Mac at my work location? Hope this is possible.
Thanks, Joost, The Netherlands
Many people use Roon at two locations. You need a Roon core at both locations. You simple enable the one you’re at. Downside is you can’t use them at the same time. ARC will also work. You just need to use your cell phone or a tablet as the source to feed your Mac. That would probably be easier.
There is a feature request:
If you want this functionality directly on your office computer without a second Roon Server installation and all of the issues involved with that, then you should consider voting for this feature request.
Edit: Just checking the status of the above feature request, it appears to be already the most voted for.
