Hi all,
help needed….
My LG OLED keeps turning on the screen saver multiple times during a track when I’m watching the lyrics, Is there a fix or a workaround for this issue?
Perhaps the lyrics display via AppleTV or ???
It’s so frustrating and seems crazy that Roon haven’t sorted this out.
Roon is genuinely ace but this issue is not on Brand.
Any one else having this issue
Cheers JP
Hi,
I have the same issue. The problem is the LG OLED TV, not Roon. It is not possible to disable the screensaver for internal LG OLED TV apps, but I read that the screensaver is not being activated for HDMI sources. So it might be possible to solve the issue with ChromeCast or Apple TV as the Roon display (did not try yet).
I can confirm that using the Chromecast with the LG TV works without this problem
