Roon iPhone remote volume control affecting Mytek DAC volume (ref#56OGXV)
· Current version of Roon in use on a Nuc PC that’s attached by a USB cable to a Mytek Brooklyn DAC. I have it set up in such a way that the volume control in Roon controls the volume of my system through the Mytek. Unfortunately, when I’m using my iPhone as a remote control, Roon uses the volume button on the iPhone to also control the volume of the Mytek through the Roon connection.
Please add a function to enable me to turn off the connection of my iPhone volume buttons to Roon. I don’t want the iPhone volume controls, which I use for business calls to make the phone calls louder and softer, to change the volume on my stereo system as controlled by the Mytek and Roon.
· The router should be irrelevant for this issue. It’s an Accel Solutions Fast 5674. No switches or extenders or VPN are in use.
Hi @Bruce_Abrams,
Thanks for writing in! We’ve checked your Roon Server logs, and everything is working as expected: volume commands reach your Brooklyn DAC and it accepts each one, so nothing is wrong with your setup.
When the Roon app is open on your iPhone, the side volume buttons control the volume of the zone you have selected. Right now there’s no setting to turn that off separately. Two things should help:
  1. On your iPhone, go to Roon Settings → Setup and set Enable Lock Screen Controls to No. The buttons will then only control Roon while the app is open, and your phone keeps its own volume whenever Roon is in the background or the phone is locked.
  2. As a safety net, set a Volume Limit for the Brooklyn DAC in Device Setup, so an accidental button press can’t push the system too loud. We noticed the volume reached 100 a few times this week.
We’ll move this thread to Feature Requests so the team sees your request for a toggle that turns off button control entirely.
