Roon Remote no longer works with Tailscale for direct IP connections (ref#GG09PQ)
· I used to be able to use room remote away from home using tailscale, has Roon changed something in the latest build as it no longer works. Arc is not a viable option for me as my library is too big. Roon Remote used to allow direct IP connections without requiring multicast discovery. Has this changed?
· I sue a standard Bt broadband router, a chord qutest and various other Dac's, headphone amps & Genelec active speakers
This isn’t a supported configuration. Roon is designed to operate on a single subnet, and ARC is intended for remote access.
Moving to Tinkering, so community may assist.
Thanks for the response. But that doesnt really answer my question. A simple yes or no & what changed is what I need so I can decide if I need to continue “tinkering” with tailscale or find another solution. If Roon Remote only supports mDNS no amount of tinkering will fix it & I already explained I cant use Arc; my phone runs hot & it constantly crashes.
AO
Something may have changed, but nothing has changed in in the latest update that affects discovery. What you describe can occur.
There are threads on this topic. However, if you provide more information about your setup, others may respond.
This may help.
Hi @mjw,
I posted my issue as you suggested in the hope someone might have a solution but I’m now being told
“Your post was flagged for moderator attention: the community feels something about the post requires manual intervention by a staff member”
Why, what have I done wrong?
This post was flagged by the community and a staff member opted to remove it.
Hi @Adeniyi_Ogunnaike,
Reviewing the flag history you created a duplicate topic rather than continuing the discussion here in your existing topic.
As the new post didn’t provide any additional information it was deleted rather than being merged.
Please continue here so all the history is together.
