I can’t get Roon to connect to Tidal. I have no problem connecting to Tidal directly. This is a new problem as of today. There have been no changes to my setup in the last couple of months. Qobuz works fine.
Try rebooting your roon core server.
Even better , disconnect your Tidal login, then reboot the core and then reconnect to Tidal
I just had the same issue yesterday when the QNAP NAS that has my Roon core did a firmware update to QTS 5.0.0.2131. Qobuz was fine, but Tidal was the problem. I ended up doing what Mike suggests and Mike’s solution fixed the problem.
Thanks everyone. The reboot was a hassle (my power light failed), but the system is up and working.
