USB DAC Connected via Raspberry PI running Ropieee
Ropieee Version - RoPieeeXL 2023.09 (1118)
Was using Topping E30 and tried switching to Cambridge Audio DACMagic and it is not showing as an end point in Roon. Logs should be available in 4b9da57b9ab8777e
Having looked at other posts here and elsewhere on the internet, try a different, basic USB cable.
Also look at the Dacmagic settings. I believe you can stop it going to sleep. This may also help as some seem to say the RPi doesn’t wake it. This affects users of Volumio too I think.
Thanks for the response. However, I am not able to find a setting to stop it going to sleep also do not find it in the manual as well. Will keep digging
