Is the volume control for the SB3 a hardware control sent from Roon 1.3, or is it the software volume built into Roon? Since the option to disable hardware volume control in the SB3 doesn’t exist like in LMS, I want to make sure I am getting maximum resolution to the unit.
Yes, Roon is using the hardware volume controls on the SB3.
