Separate section for EPs and singles
I don’t know if this is realistic, but wouldn’t there be a way to have a completely different section for the singles and one for the EPs? I have a lot of them and don’t add them to Roon because they would appear with the albums, and I love to go through my albums to find something to listen to. I would love to have three sections in my library and not everything in my albums. I guess it wouldn’t be a big problem as we already categorize them by type. And I know I can do this in focus, but I like everything clean.
Can’t you work with tags?
I said I knew about them but I wanted something separate for it.
A Workaround would be to use Focus to separate album types into groups, and then create Bookmarks for each group.
Bookmarks are dynamic, so as you add albums, singles and EPs into your library, they will be automatically added into the relevant group Bookmark… For example:
