There is a default setting that KEF Connect spits out for the low and high pass filters when the LSX II and KC62 are selected as your system:
Default
Low pass: 47.5
High pass: 67.5
Knowing what we know about the LSX II’s frequency responses aren’t these set a bit low?
If I move both of the values up should the delta between them (20Hz) remain the same? Can I go something like 75 high pass, 60 low pass with a 15Hz delta or would that give me a bump in that range?
Thanks for any clarity.
Sidenote: the default setting also turn sub gain down to -1dB
Edit:
Here are for the LS50WII’s the recommended settings
These settings would work better for the LS50 Wireless II, which has a larger mid-woofer and play a bit lower than the LSX II. On my LSX (original), I use 80 Hz LPF and HPF settings and in my room this sounds very good.
Thanks, but wouldn’t having the LPF and HPF at the exact same frequency cause a “hump”?
It may perform in that manner, but it depends on the slopes of the HPF and LPF and how they may combine in your room and system. Without a spectrum analyzer, this may need to be tuned by ear (which is what I have done). I recommend you try a few different settings and settle on what seems best in your room and system.
