I run Roon through Node and it’s internal DAC sounds very good. But I can’t figure out how to set up my D10 to it to try it as an external DAC Anyone have experience with this,?
I have the Bluesound Node 2 and send the digital signal to a Topping D70s through a coax cable. That way, the built-in DAC of the Node is not used. Instead, the D70s does the converting from digital to analog. Should work the same for the Node 2i & Topping D10.
I was wondering if the Topping does MQA through Coax, it says USB only and I was also looking to use it with my Node 2i, which doesn’t have a USB out. Thanks
Hello,
Topping D10 only input is USB, coax is output only.
Currently, the only Topping DAC that does MQA over coax is the D90ES.
