@support if you select an album (album view) and want to remove this from a TAG you applied it does
- long press upon album art
- select the 3 dots in top left corner
- and there it’s says “Add to Tag…”
perhaps this could be turned into “Add/Remove tag(s)…” or something similar?
since it not only allows to ‘ADD’ but also ‘REMOVE’ tags?
nothing serious but perhaps something which could done besides other things when one’s working on the GUI.
