You would have to ask the manufacturer if they run the same DSP on the Qb for Roon. Like I said I don’t know if Roon Ready makes some requirements there. It may well be that it sounds different, but for the 4th time this most likely has nothing to do with RAAT the protocol as the OP claimed and you should rule out more likely causes first if you want to take this question seriously.
Hello, thank you all for answering, finally activating the parametric equalizer, without modifying anything, leaving it flat, and activating the mqa decoder of the kernel (if I don’t activate it, it fails even if the dac is full decoder) the quality is better, for now I’ll hold on like this Because I want and love Roon, I bought a new streamer and it still works better. For me we can close the post until further tests with the new streamer. Thank you
