I am currently using HQ Player 4 Desktop getting fed digital stream music from Roon. I love the sound coming out of it via my Chord Mojo.
However, I would love some suggestion about the filter and NS/Dither settings that works best for Classical music (like the Chopin Concerto No 1, 2 performed by Yundi Li).
Yes I have 1 or 2 times the white noise coming out of my Chord Mojo when I set the sampling rate to 705.6/768kHz. It occasionally happens, but rather annoying and I have to turn it off.
Hi @jussi_laako : regarding the volume control, for the optimal sound quality, should I set the HQPlayer volume to around -30 to -20dB, then use the volume balls on Mojo to adjust the output volume to my Roksan K3 Power Amp?
and due to the white noise happens with my Mojo at 768kHz, now I have to set it to 376kHz. So I guess I should use the more appropriate NS5 dither, instead of the LNS15 which is more for targeting the high sampling rate?
