tares00
(Tares00)
October 13, 2023, 4:09pm
1
Affected Product
Nucleus
Nucleus Model
Nucleus Rev B
I would like to consult if iFi iPower Elite is suitable to supply power to Roon Nucleus ?
If it is, which voltage is most suitable ?
RAM & Internal Storage
1Terabite.
iFi iStream
Home Network Details
Ethernet connection
Suedkiez
(Just a fellow user like you)
October 13, 2023, 5:46pm
3
Searching the forum for iFi iPower Elite brings up a range of posts, e.g.
IFI’s response to the request:
Hi Vad ,
We would recommend the new 15v iPower Elite for use with the Roon Nucleus. If you connect an External Nas drive it also will sound better with a quieter power supply .Be careful if connecting a external USB hard drive as they may take to much current from the Roon and make the power supply run hotter than normal .
xxx
(Banned - toxicity)
October 13, 2023, 5:56pm
4
What do you believe you are going to gain by upgrading the power supply of a computer?
With respect, spend your money on something that is going to make a difference.
The Nucleus is a computer. The power supply is just an energy source. The required voltages for the CPU/RAM and drives are derived from the main energy source via on-motherboard SMPSs.
There’s no benefit to adding a LPS.
system
(system)
Closed
November 28, 2023, 7:33am
6
