I have my content on a WD My Passport USB HDD drive attached to my ROCK device. I am trying to access this HDD drive from within my Synology NAS device in order to regularly back up this content on my NAS
- The external drive is a Western Digital My Passport USB HDD.
- On the USB drive, I have the following directory: Media\Music\Music-HD
- Roon was set up to monitor changes in the “Music-HD” folder as the main content location
From within the Synology management console, I have two options to mount the remote folder, either using NFS or CIFS and both follow a different syntax
CIFS requires:
- Folder path such as: [\192.168.0.2\share](file://192.168.0.2/share)
- Username
- Password
NFS option requires:
- Folder path such as: 192.168.0.2:/volume1/share
- TCP or UDP option
I am struggling to figure out how does ROCK tread the “Volume” and “share” syntax…. What would I have in the “\ROCK\Share” and what would I have in the “//ROCK:/Volume/Share” options?
I tried different variations of:
“\ROCK\My Passport\Media\Music\Music-HD”
“\192.168.1.1\My Passport\Media\Music\Music-HD”
“\192.168.1.1\My_Passport\Media\Music\Music-HD”
“\192.168.1.1\Music-HD”
Not even sure what to use to specify the “volume/share” option in the NFS method…
If anyone has this configured to run properly using a Synology system, can you please share your syntax with me?
