All,
We are aware of TIDAL login problems at this time. This is on TIDAL’s end and it’s not possible to login to their apps either. (If you were logged into their apps, you’ll most likely get a server error message.)
If your Roon Core is already logged in then things will probably be okay – it’s new logins that are currently a problem.
Regards,
The Roon Team
Cc: @support
