Good morning, Roon. I don’t see a category for Roon hardware, nor a “suggestion box” so here goes. For many years I ran a Nucleus, which had constant signal drop out for unidentifiable reasons. I constantly had to turn the machine around to view its annoyingly positioned power switch as there was no power indicator light on the front of the machine. All my troubles went away when I installed a Titan, which had the necessary processing power for my system. In short, it’s a great machine. Might I suggest a power indicator light on the front of its successor. When one is not getting a response from the Titan upon opening the Roon app, the first considerations are whether the machine has power and if cables are properly connected. The Titan is a worst case scenario in this respect, as the power button and cable inputs are buried deeply behind the machine, which cannot easily be turned around when installed. Much as it’s pleasant not to see all this from the front or top of the machine, it is a simple practical reality. Thank you for listening.
@michael_maharam - I’ve moved your post to Feedback - all posts there are read by the Roon Labs team.
Thank you…kind of you.
