I’ve done much of the transfer of my CDs in AIFF format using the iTunes ripper. However I read in Robert Harley’s book The Complete Guide to High-End Audio (Fith Edition) that the XLD software was superior. I did a few tests but it was not conclusive. However, creating separate files for multi-disc albums works much better. Today I encounter a difficulty with an album. The tracks are all on my external drive WD MYCLOUD but they are not all imported by Roon. I checked in the RoonMount file and there are tracks that do not match the tracks on the album and others that are missing. How can I correct this situation. I read the articles you suggested to me but I do not know what to do. I attach two screenshots
After several tests and comparisons between the XLD Lossless Decoder software and the iTunes Ripper I come to the conclusion that the interface between Roon and iTunes is better and offers a more complete and easier file management than the XLD software. For example, when tracks do not appear in Roon management with Roon’s FIX TRACT GROUPING function has worked better. So I managed to solve the problems with the two albums mentioned in my previous emails. I will therefore continue the transfer of my collection of CDs in AIFF format with ITunes. Perhaps I will have a lower sound quality, but certainly less frustration. I understand the people who opt for the “turnkey” solutions mentioned by Robert Harley in his book THE COMPLETE GUIDE TO HIGH-END AUDIO. But unfortunately, this solution is rather expensive and is not currently available to me. If you know a software for RIPPING that offers better sound performance than iTunes and as much compatibility with Roon please let me know. But for now, I think iTunes will suit me perfectly. Best regards.
You’d want the R16 reference version. If you want to also check prior rips against AccurateRip database (among other things, including automated search for better artwork) then you’d also want to purchase PerfectTunes. https://www.dbpoweramp.com/purchase.htm
I found the solution to my problem of non-recognition by Roon of the information about the tracks of the albums. This problem involved only three albums. I do not have the number of albums but they have more than 10 000 tracks. Here are the steps:
I redo the request to identify Album
I indicated that no options were satisfactory
The No Matches window opened
I chose Use Basic File Information
And it worked.
I hope this information will be useful to other Roon users.
