I had an album (ripped CD) called The Singles Collection by The Specials. I just added a 2 disc album of the same name by David Bowie.
Disc #1 of the Bowie album has been added to Roon quite happily. Unfortunately, Disc #2 seems to have merged with the specials album, and also split into two albums…
Effectively, I need to “move” the first two items in the screenshot to become Bowie Disc #2, but can’t figure out how to do it. Any help much appreciated!
How do I do that sorry? Keep in mind that I only want the Bowie tracks to merge - which means I somehow have to separate them from The Specials’ tracks first!
Disc #1 shown here is a completely separate album - Disc #2 should be merged with the correct Bowie album (3rd on in my first screenshot). I hope that makes sense!
OK - I sorted it with a little bit of help from both of your posts - thanks!
I used iTunes to rip the discs, and it had put Disc #1 in a folder called David Bowie, but Disk #2 in a folder called Compilations. (Guess where the Specials album was).
I moved some files and folders around and it all looks fine now - thanks
That is the reason for all your troubles. iTunes is not very good at library management, going forward I strongly recommend that you follow the guidelines given in the Roon Knowledge Base, which are very sensible and when followed yield excellent results.
That’s fine if you have access to reliable wi-fi or affordable 4G. I live in the UK but work in Germany at the moment, so having the iTunes “matched” aac version of things works really well. I have a little DAP too, but whilst walking through airports and such its good to be connected to the phone and hear messages coming in, so the iPhone is probably still my most listened to device - even in airplane mode!
On the move, generally a pair of Sony WH-1000XM3s, but from time to time, if stationary I use a pair of iBasso IT01s IEMs (via a Dragonfly Red) for TIDAL offline content. 90+% of the time its the Sony noise cancelling 'phones though as Bluetooth and remote control is so much more practical when you’re using your phone for boarding passes etc.
I have a set of these headphones and they are fantastic. Sound quite good when used with an iPhone via bluetooth, even though the output is not lossless.
